Nvidia Shield Display Assembly Replacement
    1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Display Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Display Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the seven 6.4mm T5 Torx screws from the back panel.
      • Use the spudger to separate the front and back panels.
    2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Display Assembly Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The green grill is not screwed in so it can be pulled right out.
    3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the six 6.5mm T5 Torx screws.
      • Disconnect the power wires.
      • Peel back the copper tape and disconnect the black and white wires.
    4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the battery apparatus out once all cables are removed.
    1. Nvidia Shield Display Assembly Replacement, Removing Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Display Assembly Replacement, Removing Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Display Assembly Replacement, Removing Fan: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Cooling is important for electronics, the last thing they want is to overheat.
      • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
      • Lift the fan free after the screws and cable are removed.
    1. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
      • Once removed, the display should be able to be detached.
crwdns2935229:05crwdne2935229:0
Noel Fletcher
crwdns2935283:009/22/14crwdne2935283:0
116 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Hickman Fall 2014 crwdns2935289:0USF Tampa, Team 1-1, Hickman Fall 2014crwdne2935289:0
USFT-HICKMAN-F14S1G1
Where can o get a replacement screen
jorge valenzuela - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 7,392
