Nvidia Shield Battery Assembly Replacement
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery apparatus out once all cables are removed.
crwdns2935229:05crwdne2935229:0
Andrew Barbanera
crwdns2935283:009/20/14crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Hickman Fall 2014 crwdns2935289:0USF Tampa, Team 1-1, Hickman Fall 2014crwdne2935289:0
USFT-HICKMAN-F14S1G1
crwdns2935297:018crwdne2935297:0
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - crwdns2934203:0crwdne2934203:0
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - crwdns2934203:0crwdne2934203:0
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - crwdns2934203:0crwdne2934203:0
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,672
