crwdns2937539:0crwdnd2937539:0crwdne2937539:0
This will be a step-by-step guide to remove the battery assembly from the Nvidia Shield. This will need to be performed to install a new battery into the device. The user will not need any special skills beforehand to successfully remove the battery. The user can put the device back together with a new battery installed by following the steps in reverse. Replacing the battery in a Nvidia Shield can help improve the quality of the battery life of the product. If you notice the battery swelling or smoking, before proceeding check out the guide for what to do with a swollen battery.
Unscrew the 7 6.4mm T5 Torx screws from the back panel (screws highlighted in the photo).
Use the spudger to separate the front and back panels.
Remove the six 6.5mm T5 Torx screws (screws highlighted in the photo).
Remove the power wires.
Pull the battery apparatus out once all cables are removed.
crwdns2935229:05crwdne2935229:0
crwdns2944067:04crwdne2944067:0
For replacement batteries, are they 18650? Do I want flat top or button tops?
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
So, is this battery pack compatible? I read it has the connector in the wrong side
