Power cords can be damaged over time due to various causes. This guide will demonstrate how to replace the power cord.
Unscrew the screws from the base of the blender (These should be 5 gauge phillips head screws).
2 of the screws will be star shaped rather than phillips head.
Remove the base plate.
Identify the red and black wires topped with white-clear caps.
Use pliers to squeeze the flattened part of both caps.
The black and red wires attached to the power cord should be loose and ready to pull out.
Replace the cord by slipping the new cord's black and red wires into the caps.
Pinch the middle of the cap back to the flattened position using the pliers.
Como puedo extraer la parte donde sienta el vaso de mi licuadora ninja ct641
Como puedo extraer la base donde asienta el vaso de licuadora ninja ct641
