In order to begin this guide, you must first follow the steps in our Nutri Ninja Ninja Blender Duo BL641 Body Disassembly guide. Once you have finished, you may begin this guide.
Remove these six screws (0.5 inch 5 gauge phillip's head)
Note: 2 of the screws will be star shaped circled in blue
Lift the bottom panel off
Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
Insert pry tool in between the two plastic pieces to separate them
Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
Remove the phillip's screws from the motherboard.
Remove any plugs from the motherboard.
Desolder wires and cords. Replace old motherboard with new one, and resolder wires and cords.
Hello Will - thank you for that lesson. I am from Canada, going to CUBA and my Cuban friend needs the motherboard for a similar blender (BL 770-2.) Where do I buy one? Thanks.
what is the part number ?
I have been trying to fix my burnt board but unfortunately i think the main mcu (micro controlller is burnt) i dont know yet as i can see a whole other resistors and transistors burnt. Can someone guide if they have the component list or documentation of this board? Or if someone has any link to buy a new board for replacement?
