Numark N4 USB Port Replacement
  1. Numark N4 USB Port Replacement, Numark N4 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 USB Port Replacement, USB Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
  8. Numark N4 USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the circuit board from its housing.
  9. Numark N4 USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the USB on the circuit board.
    • Using a soldering station, carefully desolder the connection points to the USB outlet.
    • To review soldering safety and techniques, please visit How To Solder and Desolder Connections.
Erik Charlton
crwdns2935283:010/10/17crwdne2935283:0
873 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G11, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S13-G11, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S13G11
i we like to get the new board of dis numark n4
daniel benson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,693
