Numark N4 Effect button cover Replacement
  1. Numark N4 Effect button cover Replacement, Numark N4 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 Effect button cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 Effect button cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 Effect button cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 Effect button cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 Effect button cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 Effect button cover Replacement, Effect button cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the top right PCB circuit board.
  8. Numark N4 Effect button cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the two ribbon cables as shown.
  9. Numark N4 Effect button cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
  10. Numark N4 Effect button cover Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the circuit board from its housing.
  11. Numark N4 Effect button cover Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the plastic button covers as depicted.
Erik Charlton
crwdns2935283:010/10/17crwdne2935283:0
873 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G11, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S13-G11, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S13G11
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 565
