Numark N4 BP Main PCB Board Replacement
  1. Numark N4 BP Main PCB Board Replacement, Numark N4 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 BP Main PCB Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 BP Main PCB Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 BP Main PCB Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 BP Main PCB Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 BP Main PCB Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 BP Main PCB Board Replacement, Numark N4 BP Main PCB Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
  8. Numark N4 BP Main PCB Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the circuit board from its housing.
Erik Charlton
crwdns2935283:010/10/17crwdne2935283:0
900 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G11, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S13-G11, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S13G11
crwdns2942667:0crwdne2942667:0 1,831
