This guide demonstrates how to replace the rubber feet on your NuWave Brio 37001. No tools will be necessary for this guide.
The NuWave Brio 37001 has four rubber feet, located on the bottom of the device. These keep the device stable as it rests on any utilized surface. Over time, these feet may fall out, wear down, or otherwise become damaged so as to require replacement. Here's how to do so.
Make sure you visit the troubleshooting page before following this guide. There could be issues other than the heating plate that need fixing.
            Remove the basket, and flip the air fryer upside down so its feet are accessible.
            Using gentle force, pull out the damaged leg or legs.
If your Air Fryer is still unbalanced, identify the additional bad leg and repeat the process!
