NuVision TM800A510L Battery Replacement
  1. NuVision TM800A510L Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuVision TM800A510L Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Heat Gun to loosen the adhesive under the backing of the device.
    • Use prying tools to lift up the back of the device to get underneath.
    • I recommend concentrating on one side of the device at a time and making sure the device is 'almost too hot to touch' before you begin using the prying tools.
    • You can use either metal or plastic prying tools. Keep in mind, though, that metal ones may scratch the device.
  2. NuVision TM800A510L Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuVision TM800A510L Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlock all of the ribbons that cross or interfere with the battery.
    • Remove the unlocked ribbons if you can- this will make it easier to work with the battery later.
  3. NuVision TM800A510L Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use plastic prying tools to peel up the battery. Metal prying tools may puncture the battery and cause more damage. If you MUST use metal prying tools, go slow.
    • This process may take some time since the battery is held down with adhesive.
    • It is not really recommended to use the Heat Gun on the battery. However, the heat will loosen the adhesive. Therefore, if you decide to use a Heat Gun, apply the heat to the battery from underneath the device (heat the screen).
  4. NuVision TM800A510L Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder battery and wires from Motherboard HERE!
    • Once the wires are free, so is the battery. You should be able to replace the battery and its wires in full (as a package deal).
Kelsey Riggs
crwdns2935283:001/25/17crwdne2935283:0
486 crwdns2915208:0crwdne2915208:0
University of Illinois Urbana-Champaign, Team 1-1, Scrogum Spring 2017 crwdns2935289:0University of Illinois Urbana-Champaign, Team 1-1, Scrogum Spring 2017crwdne2935289:0
UICU-SCROGUM-S17S1G1
crwdns2935297:019crwdne2935297:0
crwdns2942667:0crwdne2942667:0 995
