NuTone 599 Power Brush Motor Replacement
  1. NuTone 599 Power Brush Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the removable top cover of the NuTone Model 599 Power Brush.
    • Flip the body of the vacuum over to work on the underside.
  2. NuTone 599 Power Brush Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws from the corners of the bottom cover with a Phillips #3 screwdriver.
  3. NuTone 599 Power Brush Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn over the assembly.
    • Lift the top cover off of the device.
    • The cover shouldn't put up any fuss and should come off fairly easily if the screws have been properly removed.
  4. NuTone 599 Power Brush Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws on each side of the clamp holding the motor in place.
    • Lift the clamp off of the motor.
  5. NuTone 599 Power Brush Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are only two wire nuts in the motor compartment of the brush.
    • The wire nuts are located under the light bulb to the left of the motor.
  6. NuTone 599 Power Brush Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the caps off and untwist each of the cable bundles, removing the white wire from each of them.
  7. NuTone 599 Power Brush Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new motor in the cradle and screw the clamp in place with a Phillips #3 screwdriver.
    • Run the new wires through where the old wires were so that they stick out near the cable bundles.
    • If you have ordered a new motor, follow the installation instructions that come with it as the wiring might be slightly different.
  8. NuTone 599 Power Brush Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Connect the two new cables to each of the wire bundles, being sure to match the cables with their corresponding bundles in the same way the old motor was configured.
    • Twist the wire bundles and then put on the blue caps so they are snug.
    • Remember to follow the directions for the wiring connection that come with your new motor. They could be a bit different.
  9. NuTone 599 Power Brush Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuTone 599 Power Brush Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You are done! You can now replace the cover and screws.
    • Remember to replace the drive belt onto the new motor as shown.
Jennifer Johnston-Kerr
crwdns2935283:005/04/20crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 523
