Novatel MiFi 2200 Case Replacement
  1. Novatel MiFi 2200 Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the seal has been broken all the way around, open the cases using your hands.
Justin Russo
crwdns2935283:004/15/12crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-36, Maness Spring 2012 crwdns2935289:0Cal Poly, Team 7-36, Maness Spring 2012crwdne2935289:0
CPSU-MANESS-S12S7G36
If case gets damaged, is there a place to but the case
Snehraj Merchant - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,619
