Novatel MiFi 2200 Antenna Replacement
  1. Novatel MiFi 2200 Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Antenna Replacement, Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the seal has been broken all the way around, open the cases using your hands.
  5. Novatel MiFi 2200 Antenna Replacement, Antenna: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  6. Novatel MiFi 2200 Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull out the antenna along the edge of the device.
    • There is adhesive applied to the antenna, so it may not easily detach.
  7. Novatel MiFi 2200 Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect your new antenna to the circuit board in the same position described in step 3.
  8. Novatel MiFi 2200 Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-lay antenna around the edge and over the adhesive.
    • The antenna can be fitted back into several small recesses along the groove that it was originally inside.
  9. Novatel MiFi 2200 Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Novatel MiFi 2200 Antenna Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Novatel MiFi 2200 Antenna Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
    • Snap the two halves together along the adhesive line to reconnect it as it previously was.
With a new antenna, your device should be transmitting a signal as expected. Keep in mind that you will need adhesive tape to keep the device firmly together.
Carissah
crwdns2935283:004/15/12crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-36, Maness Spring 2012 crwdns2935289:0Cal Poly, Team 7-36, Maness Spring 2012crwdne2935289:0
CPSU-MANESS-S12S7G36
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 483
