It's a simple process to replace the parts of this device. Once you have the device opened, these items can be changed: power button, power cable, heating bowl, and heating coil/pan Etc.
            Remove the two 1.3 mm Phillips #2 screws.
            Remove the S6 spanner screw.
            Split the device in half to expose the internal parts of the device.
            Again, there are two more Phillips screws to remove.
            Remove the two screws from both sides of the heating coil.
            Split the device into 2 parts to change the power button.
            Remove (flexible) plastic sleeves from the inside end of the power cable.
            Inside the product, ensure you look at the power button and try to understand this step before you take action. There are two notches, push them at the same time on both sides to push the button out of the device.
            Depress the little tab inside the top portion of the device to remove the On/Off switch.
            Replace the power button, and put the plastic sleeves in the original position.
This guide will help you to replace the power button
