Nostalgia GCM200 Power Button Replacement
crwdns2869540:0crwdne2869540:0: 593
2
16
86
593
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
It's a simple process to replace the parts of this device. Once you have the device opened, these items can be changed: power button, power cable, heating bowl, and heating coil/pan Etc.
    1. Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 1.3 mm Phillips #2 screws.
      • Remove the S6 spanner screw.
      • Carefully place these three screws somewhere safe to use later in reassembly.
    2. Nostalgia GCM200 Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Split the device in half to expose the internal parts of the device.
      • Again, there are two more Phillips screws to remove.
    3. Nostalgia GCM200 Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two screws from both sides of the heating coil.
    1. Nostalgia GCM200 Power Button Replacement, Power Button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Split the device into 2 parts to change the power button.
      • Power button hold the other parts, so be careful.
    2. Nostalgia GCM200 Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove (flexible) plastic sleeves from the inside end of the power cable.
      • You might want to use force, pull out while shaking it.
      • Inside the product, ensure you look at the power button and try to understand this step before you take action. There are two notches, push them at the same time on both sides to push the button out of the device.
    3. Nostalgia GCM200 Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Depress the little tab inside the top portion of the device to remove the On/Off switch.
    4. Nostalgia GCM200 Power Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Replace the power button, and put the plastic sleeves in the original position.
      • Great, you just finished replacing power button
    5. Nostalgia GCM200 Power Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To reassemble your device, follow these instructions in reverse order.
This guide will help you to replace the power button
Xingdi Zhou
crwdns2935283:006/27/17crwdne2935283:0
466 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G4, Liner Summer 2017 crwdns2935289:0UW Tacoma, Team S1-G4, Liner Summer 2017crwdne2935289:0
UWT-LINER-SU17S1G4
crwdns2936753:030crwdne2936753:0 86
crwdns2959996:0crwdne2959996:0 593
