This guide will show you how to replace the heating bowl.
            Remove the two 1.3 mm Phillips #2 screws.
            Remove the S6 spanner screw.
            Split the device in half to expose the internal parts of the device.
            Again, there are two more Phillips screws to remove.
            Remove the two screws from both sides of the heating coil.
            Remove the heating bowl from the plastic housing.
Follow the instruction and you will know how to replace the bowl for this device
