Follow the steps for replacing the power switch. This guide will start right after replacing power switch ends.
Lift the lid up to remove it.
Lay the popper on its side.
Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
Flip the base over to view the interior of the base panel.
Unscrew the two 10 mm Philips #2 screws from the base panel.
Remove the base and set it aside.
Locate the power switch connected to the side of the housing.
Pinch the sides of the power switch.
Push the power button up and out of the housing.
Remove the wires connected to the power switch that should be detached from the housing.
Gently pry the wires loose from the power switch with the plastic opening tool.
Remove the power switch from the housing unit.
You can now replace the power switch, if necessary.
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Remove the white top from the housing.
