Use this guide to replace the stands on the bottom of the device if they are missing or damaged.
            First, place the device on its side, making sure the switch is not facing down.
            Remove the eight 12mm Phillips #02 screws from the base.
            Gently separate the panel from the device.
            Locate the four 10mm Phillips #02 screws on the inside of the panel.
            Remove the screw of the foot you plan to replace.
                                    crwdns2935219:0crwdne2935219:0
