Nostalgia Electrics PCM805 Power Switch Replacement
  1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the switch/wire assembly inside the device.
  4. Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the insulation sleeves to expose the connector heads.
  5. Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note the color of each wire and the order you remove them.
    • Using a pair of pliers, firmly grip the base of the wire.
    • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
    • Pull the wire straight out of the switch.
    • Repeat this step for each wire.
  6. Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using pliers, pinch tabs at the top and bottom of switch.
    • While pinching the tabs, push the switch until the tabs are on the outside of the device.
  7. Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Power Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the switch from the device.
Carlton
crwdns2935283:001/13/15crwdne2935283:0
672 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-5, Hickman Winter 2015 crwdns2935289:0USF Tampa, Team 3-5, Hickman Winter 2015crwdne2935289:0
USFT-HICKMAN-W15S3G5
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,053
