Nook Tablet Speaker Assembly Replacement
    1. Nook Tablet Speaker Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the Nook over.
    2. Nook Tablet Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Tablet Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
    3. Nook Tablet Speaker Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Tablet Speaker Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
    4. Nook Tablet Speaker Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Tablet Speaker Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the spudger around the edges of the Nook to loosen the back panel.
    5. Nook Tablet Speaker Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the back panel off the Nook.
    1. Nook Tablet Speaker Assembly Replacement, Screen Bezel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Tablet Speaker Assembly Replacement, Screen Bezel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
    2. Nook Tablet Speaker Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Tablet Speaker Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
    1. Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
    1. Nook Tablet Speaker Assembly Replacement, Midframe: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
    2. Nook Tablet Speaker Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Tablet Speaker Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
    1. Nook Tablet Speaker Assembly Replacement, Removing Speaker Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your hands pull the square speaker assembly component off the motherboard.
    2. Nook Tablet Speaker Assembly Replacement, Replacing Speaker Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now place the new speaker assembly component back in the same square location.
      • As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
Josh Fisher
crwdns2935283:009/26/12crwdne2935283:0
9 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-4, Propen Fall 2012 crwdns2935289:0Cal Poly, Team 1-4, Propen Fall 2012crwdne2935289:0
CPSU-PROPEN-F12S1G4
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 2,517
