Nook HD+ Speaker Replacement
  1. Nook HD+ Speaker Replacement, Take off the Top Frame: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
  2. Nook HD+ Speaker Replacement, Remove the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook HD+ Speaker Replacement, Remove the screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Nook HD+ Speaker Replacement, Remove the Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook HD+ Speaker Replacement, Remove the Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  4. Nook HD+ Speaker Replacement, Unscrew the speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
    Knowing what part to purchase for the speaker itself would help. It doesn’t appear to be an off the shelf part so it’d have to be pulled from an existing unit. Found one on eBay, so I’ll be using this and my iFixit toolkit to make the swap.
    Jamal Taylor - crwdns2934203:0crwdne2934203:0
Alex Pelicas
crwdns2935283:010/17/14crwdne2935283:0
283 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-3, Duarte Fall 2014 crwdns2935289:0UMass Dartmouth, Team 2-3, Duarte Fall 2014crwdne2935289:0
UMASSD-DUARTE-F14S2G3
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 773
