Nook HD+ Charging Port Replacement
  1. Nook HD+ Charging Port Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook HD+ Charging Port Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook HD+ Charging Port Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook HD+ Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook HD+ Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook HD+ Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook HD+ Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook HD+ Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
  8. Nook HD+ Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook HD+ Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once removing the motherboard, flip it over and locate the charging port. Use a soldering iron to disconnect the charging port from the motherboard. If confused here's a reference.
    • Since the charging port is attached to the motherboard, it is simpler to replace both.
    • Soldering iron will be very hot and can both burn your hand and possibly damage the device.
    • Solder the new charging port to the motherboard.
Bayleigh Fouts
crwdns2935283:003/31/22crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Harley Spring 2022 crwdns2935289:0IUPUI, Team 3-3, Harley Spring 2022crwdne2935289:0
IUPUI-HARLEY-S22S3G3
Where can I obtain the replacement part?? the new charging port???
Jim Rhem - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,018
