Nook HD+ Battery Replacement
crwdns2942287:0crwdne2942287:0This guide tells you how to replace the battery on the Nook HD+ from Barnes & Noble.
crwdns2944105:0crwdne2944105:0
Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
Carefully remove center chassis from bottom frame.
Detach the battery ribbon from the motherboard.
Pry battery off of bottom frame using plastic opening tool.
Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
crwdns2935229:012crwdne2935229:0
Does model affect battery type? The replacement battery was stated so I'm just curious
Where i can buy new battery, or any similar [6000 mAh] ?
Anyone have a lead on good batteries?
clear directions, liked this guide
i have a Barnes and noble nook HD+ and how it won't charger at all.
So, does anyone have any tips for gluing everything back together? Maybe, with some sort of glue that is easy to remove again?
