Nook Color Display Replacement
crwdns2869540:0crwdne2869540:0: 4.7K
4
25
105
4,736
crwdns2955950:0crwdne2955950:0: 2
crwdns2960002:01crwdne2960002:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 8
crwdns2959974:08crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 3
crwdns2959982:03crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 20 - 30 crwdns2931279:0crwdne2931279:0
Use this guide to replace a cracked or malfunctioning display on your Nook Color tablet (identified by model number BNRV200).
The Nook Color uses an LG display made of two glass layers separated by a thin crystal layer. Your display may need to be replaced if it becomes cracked or the touchscreen no longer responds. The display could also experience "screen burn-in" which is when some of the pixels powering the display malfunction and cause uneven lighting and colors.
Before replacing the display, be sure to remove the device from any external power source and to completely shut down the device.
    1. Nook Color Display Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Color Display Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
    2. Nook Color Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Color Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
    1. Nook Color Display Replacement, Front Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
    2. Nook Color Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Color Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the front panel using the plastic opening tool.
    3. Nook Color Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Color Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift up on the connectors to disconnect them using the plastic opening tool.
    1. Nook Color Display Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook Color Display Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook Color Display Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
    2. Nook Color Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
    3. Nook Color Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook Color Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the motherboard gently from the side with the larger connector ribbon.
      • Slide the white cable gently from underneath its holding place to free the motherboard completely.
      • Remove the motherboard carefully from the device.
    1. Nook Color Display Replacement, Display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook Color Display Replacement, Display: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook Color Display Replacement, Display: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to gently pry the display upwards.
      • Lift the display out with your hands until the display has separated from the frame.
crwdns2935229:08crwdne2935229:0
Matthew Perdomo
crwdns2935283:001/20/15crwdne2935283:0
536 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-5, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 11-5, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S11G5
crwdns2935297:084crwdne2935297:0
this site doesn't sell the Nook Color display. Where did you get yours?
Suzette Garoutte - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 105
crwdns2959996:0crwdne2959996:0 4,736
