Nokia N70 Display Replacement
  1. Nokia N70 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the phone.
  5. Nokia N70 Display Replacement, Keypad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N70 Display Replacement, Keypad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N70 Display Replacement, Keypad: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N70 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N70 Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Display Replacement, Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a torx T6 screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia N70 Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
  9. Nokia N70 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia N70 Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect.
    • Remove the ribbon connection that connects the two circuit boards.
  10. Nokia N70 Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N70 Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N70 Display Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While pulling back each of the clamps marked in the image, lift out each side of the screen independently.
    • Be careful when using the plastic prying tool to not scratch the display.
crwdns2935229:08crwdne2935229:0
Justin
crwdns2935283:010/12/11crwdne2935283:0
984 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-2, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 6-2, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S6G2
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 8,887
