Nokia N70 Back Camera Replacement
    1. Nokia N70 Back Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the phone as shown.
      • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
    2. Nokia N70 Back Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery cover by lifting it away from the phone.
    3. Nokia N70 Back Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the plastic opening tool into the marked space.
      • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
    4. Nokia N70 Back Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the phone.
    1. Nokia N70 Back Camera Replacement, Keypad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement, Keypad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement, Keypad: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the plastic opening tool in the marked areas in between the front and back covers.
      • Pry each corner with the plastic opening tool until the front case completely detaches.
    2. Nokia N70 Back Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Orient the phone so that the keypad is facing you.
      • Remove the keypad by lifting it away from the phone.
    1. Nokia N70 Back Camera Replacement, Back Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia N70 Back Camera Replacement, Back Camera: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using T6 Torx screwdriver remove the six 15 mm torx screws.
    2. Nokia N70 Back Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
      • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
    3. Nokia N70 Back Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia N70 Back Camera Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the rear circuit board by flipping over the front panel.
      • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
      • Caution: Be careful when prying camera out of the slot for the connections are fragile.
Justin
crwdns2935283:010/12/11crwdne2935283:0
1,026 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-2, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 6-2, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S6G2
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 9,486
