This guide will show you how to replace the battery on a Nokia Lumia 930 smartphone.
Pull the SIM card holder out of the top of the phone using your fingernail.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
Remove the 4mm Torx #4 screw that's securing the battery connector.
Use tweezers to remove the battery connector strap.
Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
Use the flat end of a spudger to pry the battery cover from the phone's frame.
Use the flat end of the spudger to lift up the battery.
