crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
Pull out the holder until it is completely separate.
Slide a plastic opening tool under the back cover.
Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
Remove the 3 screws using the T7 Torx screwdriver.
Unclip the black tab connector.
Unclip the two orange tabs.
Remove the four silver screws using the T5 Torx screwdriver.
Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
Push the screen from the inside of the phone.
Pull the screen off.
Locate the grey speaker/camera cover.
Carefully remove the cover with either a pair of tweezers or your fingers.
With a pair of tweezers, gently remove the orange colored tab closest to the speaker.
Pull at the orange section until it becomes loose.
Pull vertically on the same orange section until the front camera comes out.
Remove the two black screws by using the T5 Torx screwdriver.
Pry off the metal vibrating unit using tweezers.
Insert the tweezers under the corner of the battery, and lift out.
Add markers to steps 10 and 11 for clarity. Add the battery to the “parts” section. For step 5 make sure the bullet color matches the marking color. Remember to add an introduction.
\Some steps unnecessary e.g. remving the screen.
Also some other parts.
Use your brain.
