Nokia Lumia 900 Motherboard Replacement
  1. Nokia Lumia 900 Motherboard Replacement, Opening The Phone: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 900 Motherboard Replacement, Opening The Phone: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Motherboard Replacement, Removing the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach connector from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Nokia Lumia 900 Motherboard Replacement, Detach the Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach Connectors that are attached from the screen to the motherboard.
    • Screen can now be removed with little effort.
  4. Nokia Lumia 900 Motherboard Replacement, Removing Rubber Gaskets: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of tweezers, remove rubber gaskets that are holding the motherboard in place.
  5. Nokia Lumia 900 Motherboard Replacement, Removing the Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting in the bottom left corner of the device, insert a wedge between the motherboard and the case.
    • Gently pull up with the wedge allowing for the motherboard to gently click out of place.
    • Gradually repeat this process around the entire motherboard until it becomes easy enough to remove completley from the casing.
Joshua Crosman
crwdns2935283:010/20/14crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S5G1
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,688
