Nokia Lumia 900 Front Camera Replacement
  1. Nokia Lumia 900 Front Camera Replacement, Opening The Phone: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 900 Front Camera Replacement, Opening The Phone: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
    This guide is forgetting to mention you have to take out the Sim card tray and the locking bar that holds the LCD in, if you don't you will break the housing and screen.
    Matthew Babcock - crwdns2934203:0crwdne2934203:0
  2. Nokia Lumia 900 Front Camera Replacement, Detach Ribbon: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach camera ribbon from motherboard
  3. Nokia Lumia 900 Front Camera Replacement, Remove Camera: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel camera off of adhesive surface
    • Use caution when removing camera as it is fragile
  4. Nokia Lumia 900 Front Camera Replacement, Installing New Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply adhesive to back of camera
    • Attach ribbon to motherboard
    • Press down on camera for 60 seconds
    • Let dry for 5 minutes
  5. Nokia Lumia 900 Front Camera Replacement, Reassembling Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Joshua Crosman
crwdns2935283:010/20/14crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S5G1
Is also forgot to tell about the plate between screen and battery that is glued to the battery
John Bork - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 588
