Nokia Lumia 900 Front Camera Replacement
  1. Nokia Lumia 900 Front Camera Replacement, Opening The Phone: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 900 Front Camera Replacement, Opening The Phone: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Front Camera Replacement, Detach Ribbon: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach camera ribbon from motherboard
  3. Nokia Lumia 900 Front Camera Replacement, Remove Camera: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel camera off of adhesive surface
    • Use caution when removing camera as it is fragile
  4. Nokia Lumia 900 Front Camera Replacement, Installing New Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply adhesive to back of camera
    • Attach ribbon to motherboard
    • Press down on camera for 60 seconds
    • Let dry for 5 minutes
  5. Nokia Lumia 900 Front Camera Replacement, Reassembling Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Joshua Crosman
crwdns2935283:010/20/14crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S5G1
Is also forgot to tell about the plate between screen and battery that is glued to the battery
John Bork - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 599
