Nokia Lumia 720 Display Assembly Replacement
crwdns2936621:0crwdne2936621:0
  1. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Display Assembly Replacement, BATTERY: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, BATTERY: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, BATTERY: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
  5. Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
  6. Nokia Lumia 720 Display Assembly Replacement, Logic Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Logic Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Logic Board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the Volume, Power and camera buttons flex cable.
    • Remove the 4x Torx T4 screws.
    • Slightly lift the board
    • Slowly and gently unstuck the light sensor from the middle frame.
  7. Nokia Lumia 720 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the Display Assembly flex cable.
    • Disconnect the Charging Dock Board flex cable.
    • Remove the Main board.
  8. Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a hair dryer and warm the flex cable.
    • Careful unstuck the flex cable from the middle frame.
    • Micro USB connector
    • Microphone
  9. Nokia Lumia 720 Display Assembly Replacement, EARPIECE: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, EARPIECE: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a tool with a sharp point and carefully unstuck the earpiece.
  10. Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When you start with the removing the ribbon cable be careful with the buttons and with the small black cups on it.
    • Warm the flex cable and detach it.
  11. Nokia Lumia 720 Display Assembly Replacement, Display Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now you can start with the reassembling, but before you place the back cover, test the new display assembly.
    • When you put the lid be careful with the volume buttons.
  12. Nokia Lumia 720 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • That's all.
    • Did you do it successfully?
crwdns2935229:05crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194 733 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01 397crwdne2935297:0
crwdns2942667:0crwdne2942667:0 5,972
