Nokia Lumia 635 Display Assembly Replacement
crwdns2936621:0crwdne2936621:0
  1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory cards.
    • Remove the black tape near to the loudspeaker.
  2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, SCREWS: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, SCREWS: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 9x Torx T4 screws.
    • Two of them are with the same head size but with a different length.
  3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to remove the back cover.
    • Careful unhook the display assembly flex cable.
  4. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
    Not sure if Step 4 'testing' is on the right place. I would assume it's after Step 7 ?
    deRahier - crwdns2934203:0crwdne2934203:0
  5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put some scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
  6. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start the separating from the upper right corner, where you have an hole in the middle frame.
    • Use plastic tool to prevent the middle frame from scratches.
    • Work slowly, you can cut your fingers.
  7. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean the middle farme.
    • Put adhesive tape 3MM.
    • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
    • It's easier if you order the spare part together with an adhesive tape.
    • Install the display assembly.
  8. Nokia Lumia 635 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 635 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • That's all.
    • Did you do it successfully?
crwdns2935229:05crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194,676 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01,376crwdne2935297:0
Exactly what I needed! Step by step detailed instructions along with what tools I would need. Heating it up took longer than expected & it took me longer than 30 min, but I actually set aside 2 hours to replace my screen. Woohoo I finally I have a new screen & I did it all on my own...well with the amazing help from ZFix ;D
beatriz_ibre - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 10,057
