Nokia Lumia 635, 630 - Hard Reset
crwdns2936621:0crwdne2936621:0
  1. Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the phone off.
    • Press and hold the power button. When the phone vibrates, release it and press and hold the volume down button until you see the exclamation mark on the screen.
    • Another way to do this - press and hold the volume down button and connect the charger.
    • Whit the exclamation mark on the screen press this sequence of keys:
    • -> Volume Up
    • -> Volume Down
    • -> Power button
    • -> Volume Down
    Mine won't go to ! It keeps rebooting to Nokia
    Trillix Wolfie - crwdns2934203:0crwdne2934203:0
    My phone ignores the sequence. It was set up as a child phone, and there’s no “reset phone” button in the about menu. It in fact doesn’t even have the about menu. And trying to reset it using buttons, I get exclamation mark, and once I push the Volume Up button, it starts to boot normally and ignores the rest.
    Sergey Kofanov - crwdns2934203:0crwdne2934203:0
    THanks its a useful ways it works on my phone…nice one
    Abasi Kadewele - crwdns2934203:0crwdne2934203:0
    thank you it worked on my phone!!! I’m very glad! Thank you again!
    szabo_istvan78 - crwdns2934203:0crwdne2934203:0
    When I turn on my Lumia 635, it displays "Nokia" and goes off then comes on again and only display Nokia. After resetting it, it continues the same
    Frank Inyiama - crwdns2934203:0crwdne2934203:0
    my lumia phone was switch off showing Nokia sign in every 10 seconds. after hard reset , it is showing charging sign. what to do next .
    flora - crwdns2934203:0crwdne2934203:0
    Thank you, it worked on my phone. I’m very happy now
    Arham Jahangir - crwdns2934203:0crwdne2934203:0
    Works perfectly,
    thanks.
    And just a note for everyone, TAKE YOUR SD CARD OUT FIRST!!!!! IT WILL WIPE THE DATA!!!!
    Austin Wilson - crwdns2934203:0crwdne2934203:0
    Worked perfectly thank you for this info!!
    jessiecrego83 - crwdns2934203:0crwdne2934203:0
    non riesco a resettare il mio lumia, sarà perchè il sistema operativo è stato aggiornato con il 10?
    qualcuno può suggerirmi qualcosa?
    rosario marchica - crwdns2934203:0crwdne2934203:0
crwdns2935229:064crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194.676 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01.376crwdne2935297:0
crwdns2947412:032crwdne2947412:0
Hey, I have done it on the computer, reload the windows but still I get the exclamanition, also the battery is death right now and I don't know how its gonna charge?
remzicanakile - crwdns2934203:0crwdne2934203:0
Phone get rain water, I want to mention it.It opens dont problenm but that sign (!) gonna drive me mad!!
Will this delete contact numbers
suryansh - crwdns2934203:0crwdne2934203:0
Yes if you have the numbers stored somewhere not on the phone then you just have to re add them
Abigail Hard -
will my number still be there and is the phone still active, Do I need to have it reactivated??
or should i take out the sim card first??
robcamp1963 - crwdns2934203:0crwdne2934203:0
Now would I bypass a reset protection notification
STUDENT James Chapman - crwdns2934203:0crwdne2934203:0
It worked for me....thanks a whole lot.....am happy
Christian smart -
Its very Useful... Thank you.... -:)
Madhu K - crwdns2934203:0crwdne2934203:0
It didn't work now I have a sad face on the screen and phone won't cut on
Monicia - crwdns2934203:0crwdne2934203:0
me too it does not work! and why ?
queeniebautista - crwdns2934203:0crwdne2934203:0
Thanks a million. It worked and a huge problem solved. Thanks again.
Ibrahim Nisar - crwdns2934203:0crwdne2934203:0
When I turn on my Lumia 630, it displays "Nokia" and goes off then comes on again and only display Nokia....will this method bring it back to normal?
Christian smart - crwdns2934203:0crwdne2934203:0
Mine is the same too. I don't know what to do
Frank Inyiama -
It's not working, I repeated the process multiple times and I keep getting the same outcome, it just goes to the Nokia screen, and boots up the same
Anthony Martin - crwdns2934203:0crwdne2934203:0
I have done it but still facing the same problem. The problem is that my sister has given me Nokia Lumia 635 and it is having a problem of ‘This device is locked to a specific mobile operator. Contact your mobile operator for the unlock code.
Beal Geesus - crwdns2934203:0crwdne2934203:0
This method always had worked for me.
Manheche Baptista - crwdns2934203:0crwdne2934203:0
This method always really worked for me.
thank you very much. the method is really superb
sssebyongaabdulnoor - crwdns2934203:0crwdne2934203:0
Not work for me. Hardware reset done. anyway thanks for the details.
Pabodha Lankathilaka - crwdns2934203:0crwdne2934203:0
There is a sad face and the phone won't start
Henry Ncube - crwdns2934203:0crwdne2934203:0
Phone shows a sad face and will not open
the phone loads up to a blue screen then says complete and also says below it if you'd like to know more you can search online later or this and onto of that it says 0% then error.0xc00002e3
carlos gonzalez - crwdns2934203:0crwdne2934203:0
how on god’s green earth are you going to do this “to reassemble your device follow this backward” bro, it’s a Fudging factory reset, not a dissasembaly
alexgamertheminer - crwdns2934203:0crwdne2934203:0
Hallo, ich habe noch ein altes Nokia RM 974 in grün. Ich habe einen Hard-Reset durchgeführt. Nach den beiden Zahnrädern kommt aber leider nur ein ablehnendes und es resettet neu, und alles wiederholt sich. Haben Sie dafür eine Lösung?
Ralf Hader - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 167
crwdns2942667:0crwdne2942667:0 240,991
