Nokia Lumia 520 Power/Volume Switch Replacement
  1. Nokia Lumia 520 Power/Volume Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger (non damaging nylon stick tool) into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the spudger gently to separate the back cover of the phone and the body of the phone.
  3. Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger into the space between the battery and the battery holder, then lift gently to remove the battery.
  4. Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the eight screws in the body of the phone using the Torx screw driver (T4).
    • Once the screws are removed keep them nearby for convenience when repairing the phone later.
  5. Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly and carefully use your spudger to remove the plastic casing over the motherboard.
  6. Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your spudger, carefully unclip the digitizer touch screen cable. Next unclip the display screen cable.
  7. Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the motherboard with your hands.
    • Flip it over. Then turn it 90 degrees counterclockwise. Ensure the switches (pictured) are facing you.
    • You will see four small switches close to the side of the circuit board.
  8. Nokia Lumia 520 Power/Volume Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently take the power/volume switches off using a pair of needle nose pliers. Once removed, gently clean the solder that was there. Replace the solder with a new coat of solder.
    • Check out iFixit's soldering guides, here.
Eduardo Perez
crwdns2935283:011/03/15crwdne2935283:0
189 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-5, Bhusal Fall 2015crwdne2935289:0
UMASSD-BHUSAL-F15S1G5
crwdns2942667:0crwdne2942667:0 5,896
