Battery draining quickly? It may be time for a new one. Use this guide to help you replace your phone's battery.
Insert the spudger (non damaging nylon stick tool) into the crevice located between the back cover of the phone and the body of the phone.
Lift the spudger gently to separate the back cover of the phone and the body of the phone.
Insert the spudger into the space between the battery and the battery holder, then lift gently to remove the battery.
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
Greetings I have a Lumia & I need the Screen and Battery,so how can I get those 2?
