I apologize for the grainy photos, I don't have a very good camera.
Remove back cover by sliding downwards.
Remove battery and sim card (if applicable).
Remove two 5mm-long screws on the left and right using a T6 Torx screwdriver.
Flip phone over to front.
Insert opening pick underneath headphone jack and pry around edge of phone until front cover pops off.
Remove four 5mm-long screws in the corners of the motherboard using a Torx T6 screwdriver.
Pull one plastic clip out of the way and gently lift and pull the motherboard out of the housing.
Flip phone over and use Spudger to move metal clips out of the way.
Flip phone back over and remove metal screen housing.
Use Spudger to lift the screen cable, and remove screen.
