Nokia Asha 201 Screen Replacement
crwdns2869540:0crwdne2869540:0: 1127
3
12
58
1.127
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
If your Nokia Asha 201’s screen has shattered, is malfunctioning and/or requires a replacement use this guide to change it. The Nokia Asha 201 is a single-sim budget phone added to the Nokia Asha family released in Q4 2011. This is not to be confused with the Nokia Asha 200 which is a double sim version of the former, however the screen replacement steps are the same.
Before getting started make sure you have a Nokia Asha 201 screen to replace the old one with. It would be best to use an official screen from Nokia to avoid any incompatibility. It is through the screen that one is able to see any information from their phone so it is important not to damage the surface of the new screen you will be replacing with, handle it with care.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
    1. Nokia Asha 201 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove back cover of device by pressing firmly and sliding the cover off.
    2. Nokia Asha 201 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your finger, lift up on battery to remove from the device.
    3. Nokia Asha 201 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a screwdriver, remove the two screws from the back case.
    4. Nokia Asha 201 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the front case using a iFixit opening tool.
    5. Nokia Asha 201 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Keyboard with your hands.
    6. Nokia Asha 201 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four screws pictured here.
    7. Nokia Asha 201 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the iFixit opening tool, separate the screen from motherboard.
      • Unplug your old screen from your phone, unpack your new one and gently plug in the new screen. Make sure you plug in the screen just like the old one was placed in the phone.
    8. Nokia Asha 201 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After plugging in the new screen put back the screen onto the motherboard.
    9. Nokia Asha 201 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a philips #00 screwdriver to put back the four 3.5 mm screws trays pictured here.
    10. Nokia Asha 201 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers place the keyboard back like in the picture.
    11. Nokia Asha 201 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers and the Phillips opening tool reposition and adjust the front case onto the phone.
    12. Nokia Asha 201 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Phillips #0 screwdriver, screw back in the two screws to the back case.
    13. Nokia Asha 201 Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers put back the battery in the back of the phone properly.
    14. Nokia Asha 201 Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide back in the phone cover to the back of the device.
Replacing Nokia Asha 201 screen takes several steps. These steps should be followed precisely to have the screen replaced without complications. Each step should be done before start doing the next step. After you’re done following these steps, you should start reassembling the device. To reassemble the device, follow these instructions in reverse order.
Amanda Tresgallos
crwdns2935283:010/10/19crwdne2935283:0
158 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G3, Leahy Fall 2019 crwdns2935289:0USF Tampa, Team S1-G3, Leahy Fall 2019crwdne2935289:0
USFT-LEAHY-F19S1G3
crwdns2936753:030crwdne2936753:0 58
crwdns2959996:0crwdne2959996:0 1,127
