Use this guide to replace the faulty or unresponsive keyboard on your Nokia Asha 201.
A properly functioning keyboard is a crucial component of your phone, as it allows you to type messages, type phone numbers to make phone calls, and search on the internet. If your keyboard is missing keys or not responding how it should be, a keyboard replacement is necessary to restore the device to functioning correctly.
Before beginning the replacement, try cleaning the keyboard to ensure debris or a sticky substance is not the issue. You may even benefit from a second opinion before proceeding. Once you have confirmed the problem, follow this guide to replace the keyboard safely and efficiently.
Power off your phone and remove the battery before starting this replacement. Gather all the necessary tools, including a small screwdriver to remove the screws on the phone and an iFixit opening tool. Utilizing these tools ensures you avoid damaging the device when disassembling it.
Handle all components of the phone with care, and make sure to keep track of all the parts, especially the screws, to ensure a smooth reassembly.
After following this essential step-by-step guide, your Nokia Asha 201 keyboard will return to new.
            Remove back cover of device by pressing firmly and sliding the cover off.
            Remove the two screws found on the left and right side of the phone.
            Remove the front case using the iFixit opening tool.
