This guide shows you how to remove or install the SIM card in case of needed replacement.
Locate the button on the bottom of the back cover.
Depress the button with your finger.
While the button is depressed, slide the back cover off of the phone.
Place the phone so that the battery is face up.
Insert a screwdriver or spudger into the crevice above the battery.
Use a screwdriver or spudger to lift the battery out of the casing.
Place the spudger under the plastic cover and lightly lift.
Insert the SIM Card under the plastic cover and close.
