Your Nokia 8265 keypad may eventually become sticky or unresponsive as a result of spills, debris buildup, or normal wear and tear. Thankfully, changing or cleaning the keypad is a simple procedure that requires minimal tools. The keypad of your Nokia 8265 can be removed, cleaned, and replaced with the help of these instructions.
Follow the instructions to replace the keypad for your Nokia 8265 phone. Before you begin, make sure to turn off your phone and unplug it from the charger.
Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
Once popped off, remove the faceplate entirely, exposing the keypad.
You can pick up the keypad with ease, as it is not attached to the phone itself.
To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
