Nokia 8260 Keypad Replacement
  1. Nokia 8260 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the cell phone.
  2. Nokia 8260 Keypad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Keypad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Keypad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
  5. Nokia 8260 Keypad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Keypad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Keypad Replacement, Antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Keypad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Keypad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna door.
  10. Nokia 8260 Keypad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 Keypad Replacement, Circuit Board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 Keypad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back covering.
  13. Nokia 8260 Keypad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws at the top.
  14. Nokia 8260 Keypad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  15. Nokia 8260 Keypad Replacement, Keypad: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic border lying on the keypad.
  16. Nokia 8260 Keypad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
Aaron Jen
crwdns2935283:004/11/10crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 27-94, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 27-94, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S27G94
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 15,944
