Nokia 8260 Circuit Board Replacement
    1. Nokia 8260 Circuit Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off the cell phone.
    2. Nokia 8260 Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press down on the round button on the back cover of the phone.
    3. Nokia 8260 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the back cover down while still pressing the button.
    4. Nokia 8260 Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back cover.
    5. Nokia 8260 Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press the end of the battery towards the top of the phone.
    6. Nokia 8260 Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the battery outwards while still pressing it upwards till it pops out.
      • You may need to take several attempts to lift out the battery.
    1. Nokia 8260 Circuit Board Replacement, Antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
      • This step may be a bit difficult if you are removing the antenna for the first time.
    2. Nokia 8260 Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry open the antenna door by pulling down the top of the spudger
    3. Nokia 8260 Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the antenna door.
    4. Nokia 8260 Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
      • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
      • Try to keep the antenna as flat as possible. Do not bend it.
    1. Nokia 8260 Circuit Board Replacement, Circuit Board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
      • The two bottom screws are longer than the upper three.
    2. Nokia 8260 Circuit Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back covering.
    3. Nokia 8260 Circuit Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two screws at the top.
    4. Nokia 8260 Circuit Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the metal plating and the circuit board.
      • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
      • The LCD will be attached to the circuit board.
Aaron Jen
crwdns2935283:004/11/10crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 27-94, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 27-94, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S27G94
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 3,312
