This guide will show how to remove the phone's logic board.
Press the button on the bottom of the rear cover.
Keep the button pressed while pulling the cover downward to remove the back cover.
Lift the cover off.
Push the battery down from the top and pull it out.
Grip the front cover from the bottom.
Remove the six screws using a T6 torx screwdriver.
Insert spudger along edge of assembly and gently lift assembly away from case
The logic board now sits on top of the phone.
Lift the logic board out of the phone.
