This guide gives instructions on replacing the Nokia 6560 display.
Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
Lift off your cell phone's back cover.
Use your index finger to first push down and then lift up the battery as shown.
Remove the battery from your cell phone.
Open the front cover of your cell phone with the plastic opening tool or finger nail.
Lift the cover upwards, starting from the bottom below the keypad.
Lift the keypad off of the keyboard as it is not attached to the phone anymore.
Unscrew the six T6 torx screws which attach the frame to the cell phone case.
Lift the frame off of your cell phone.
Lift the keyboard out of the plastic frame.
Use the plastic opening tool to unmount the thin metal frame at the tab connections. You must do this on both sides.
Lift the thin metal frame off of the plastic frame.
Pull the sides of the plastic frame apart in order to loosen the display.
Take the display out of the plastic frame.
