Nokia 6350-1b Display Screen Replacement
    1. Nokia 6350-1b Display Screen Replacement, Display Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6350-1b Display Screen Replacement, Display Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using an iFixit opening tool, separate the plastic frame and the rest of the phone.
      • Move the opening tool along the frame, unlocking all of the locks that keep the frame in place.
      • Remove the plastic frame and set aside.
      • Be careful not to pry too hard; doing so could crack the plastic frame.
    2. Nokia 6350-1b Display Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
      • Using an opening tool, pry between the screen cover (top left) and the phone frame (top right).
      • To separate, unlock the various groove-like locks on all four sides of the phone.
      • Carefully remove the screen cover (top left) to reveal the logic board (bottom).
      • Keep track of the four small screws. They will be needed to put the phone back together.
    3. Nokia 6350-1b Display Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the flex cable from the logic board.
      • Disconnect the damaged LCD display screen and remove from the device.
      • Remember to dispose of the damaged LCD display screen responsibly; do not throw away with household trash, as electronic parts are considered household hazardous waste (HHW).
    4. Nokia 6350-1b Display Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Connect the new LCD display screen to the phone.
      • Reconnect the logic board (bottom right) to the flex cable (gold tab).
    5. Nokia 6350-1b Display Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the T-5 screwdriver, screw the four screws back into the phone.
    6. Nokia 6350-1b Display Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the cover back on the device so that it is in the correct position to be reinstalled. Use the opening tool from earlier to direct the cover with precision.
      • Press gently on the cover so that it snaps back into place.
Anna
crwdns2935283:004/13/12crwdne2935283:0
25 crwdns2915208:0crwdne2915208:0
SUNY Cortland, Team 1-2, Getto Spring 2012 crwdns2935289:0SUNY Cortland, Team 1-2, Getto Spring 2012crwdne2935289:0
SUNYCORT-GETTO-S12S1G2
crwdns2935297:048crwdne2935297:0
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 2,366
