Nokia 6086 Keypad Replacement
crwdns2869540:0crwdne2869540:0: 1878
2
21
81
1.878
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Replacing a faulty keypad.
    1. Nokia 6086 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off the phone.
      • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
      • Position the phone so that the back side is in view.
    2. Nokia 6086 Keypad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the back battery cover.
      • Apply pressure on the cover while simultaneously sliding the cover downward.
    3. Nokia 6086 Keypad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the iPod opening tool between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • The battery lifts out of the phone fast and easily.
      • Carefully lift the battery out of the phone.
    1. Nokia 6086 Keypad Replacement, Upper Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the phone so that the back of the phone is facing forward.
      • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
      • In this picture, the upper cover has already been removed.
    2. Nokia 6086 Keypad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the iPod opening tool under the tabs near the top of the phone.
      • Slide the iPod Opening Tool upwards.
      • This will pop the tabs and release the upper part of the phone.
      • Repeat for the left and the right sides.
    3. Nokia 6086 Keypad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
      • Lift the iPod opening tool to pop open the clips.
      • This will release the upper back cover of the phone.
    4. Nokia 6086 Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push upward on the top back cover using two thumbs.
      • This will remove the top back cover from the phone.
    1. Nokia 6086 Keypad Replacement, Base of The Phone: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6086 Keypad Replacement, Base of The Phone: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the four screws.
      • Remove the screws using a T6 Torx screwdriver.
    2. Nokia 6086 Keypad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the phone over.
      • Gently pull apart the phone.
      • Start at the bottom of the phone and pull outward.
      • There are plastic catches on the middle of each side. These should pop free as you pull.
      • Be careful, the phone will separate into two sections.
    3. Nokia 6086 Keypad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The phone should now be in two different sections.
      • 1) The logic board and the back cover
      • 2) The keypad and the rest of the phone
    1. Nokia 6086 Keypad Replacement, Keypad: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the keypad in view.
    2. Nokia 6086 Keypad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6086 Keypad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the keypad from the phone by lifting the keypad off the phone.
    3. Nokia 6086 Keypad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The keypad should be detached.
Caitlin Rahm
crwdns2935283:004/15/10crwdne2935283:0
78 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 26-30, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 26-30, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S26G30
crwdns2935297:0108crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 81
crwdns2959996:0crwdne2959996:0 1,878
