Nokia 6010 Microphone Replacement
  1. Nokia 6010 Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Microphone Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 Microphone Replacement, SIM Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Nokia 6010 Microphone Replacement, Keypad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Microphone Replacement, Keypad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 Microphone Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
  6. Nokia 6010 Microphone Replacement, LCD Screen and Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Microphone Replacement, LCD Screen and Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
  7. Nokia 6010 Microphone Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
  8. Nokia 6010 Microphone Replacement, Logic Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Microphone Replacement, Logic Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
  9. Nokia 6010 Microphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
  10. Nokia 6010 Microphone Replacement, Microphone: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement, Microphone: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Microphone Replacement, Microphone: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or a finger to lift the the microphone off the body of the phone.
    • The microphone is attached to the phone with glue, but removes easily with a spudger.
Nicholas Hanne
crwdns2935283:001/20/10crwdne2935283:0
129 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-45, Regan Winter 2010 crwdns2935289:0Cal Poly, Team 14-45, Regan Winter 2010crwdne2935289:0
CPSU-REGAN-W10S14G45
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,742
