Nokia 6010 Charger Connector Replacement
    1. Nokia 6010 Charger Connector Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press the small tab on the bottom of the back of the phone.
      • Push the back case upward towards the power button. The back case will then pop off.
      • It requires some force, so be careful.
    2. Nokia 6010 Charger Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Charger Connector Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the battery near the bottom and pry up.
    1. Nokia 6010 Charger Connector Replacement, SIM Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With one hand, press the ridged tab near the visible side of the SIM card.
      • Slide the card out with your other hand.
    1. Nokia 6010 Charger Connector Replacement, Keypad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Charger Connector Replacement, Keypad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the phone on either the sides, the top, or the bottom.
      • Pull the front case away from the rest of the phone.
      • There are no special tabs to keep it in place so it should wiggle free easily.
    2. Nokia 6010 Charger Connector Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the keypad away from the body of the phone.
      • The keypad is the rubber-backed piece with the number keys.
    1. Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six screws around the front of the phone body with a T6 screwdriver.
    2. Nokia 6010 Charger Connector Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert your finger underneath the speaker piece and pry away from the phone body.
      • The plastic layer containing the LCD screen and speaker takes some force to remove.
      • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
      • The LCD and the speaker are attached to the same piece and must be replaced together.
    1. Nokia 6010 Charger Connector Replacement, Logic Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 6010 Charger Connector Replacement, Logic Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the rubber power button away from the body of the phone.
      • The power button is the rubber piece on the top of the phone.
    2. Nokia 6010 Charger Connector Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a finger between the phone body and logic board.
      • The logic board is the green plastic piece with circuitry attached.
      • Pull the board away gently.
      • The board is delicate and contains electronic parts. Be careful while removing it.
    1. Nokia 6010 Charger Connector Replacement, Charger Connector: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement, Charger Connector: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 6010 Charger Connector Replacement, Charger Connector: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a spudger tool between the phone casing and the charger connector.
      • Pry the key away from the phone gently.
      • Be careful not to bend the metal leads while handling the power key.
Nicholas Hanne
crwdns2935283:001/20/10crwdne2935283:0
129 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-45, Regan Winter 2010 crwdns2935289:0Cal Poly, Team 14-45, Regan Winter 2010crwdne2935289:0
CPSU-REGAN-W10S14G45
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 4,692
