Nokia 5310b XpressMusic Motherboard Replacement
  1. Nokia 5310b XpressMusic Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the black battery cover down and off the phone with your thumb to remove it.
    • The battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the battery with a fingernail to remove it from the back of the phone.
    • Keep the battery removed for the next steps
    • The battery may be replaced or repaired at this step.
  3. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 first to remove the camera cover and two T6 screws, BEFORE removing the faceplate.
    • Find a small latch under the music keys and in the middle of each side of the faceplate.
    • Gently lift the edges of the front faceplate off the phone using a spudger.
  4. Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the phone over to the front side.
    • Lift up the keypad from the bottom with either a spudger or your finger.
    • At this time the keypad can be removed and replaced.
  5. Nokia 5310b XpressMusic Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the phone over to the back side.
    • Unsnap the back camera cover from the phone.
    • Lift to remove the back camera cover from the phone after it has been unsnapped.
  6. Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the two screws on either side of the camera with the T6 Torx Screwdriver head.
    • Unscrew and remove the 4 screws located at each corner of the white keypad base using the T6 Torx Screwdriver head.
  7. Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard.
  8. Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the 2 metal clips located in the middle of the left and right sides of the motherboard.
    • Pry the 2 metal clips open up by using a spudger.
    • At this point the phone should come apart into 2 pieces (the motherboard/LCD screen and the faceplate).
Max Kirby
crwdns2935283:005/01/11crwdne2935283:0
518 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-14, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-14, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G14
Step 5 and 6 must be performed before step 3, otherwise, you will dislodge the thread from the front plate. so you have to remove the camera cover first, remove the 2 screws then you can remove the front plate without breaking anything.
Vincent Tschanz - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,194
